P pal251 Getting comfortable Mar 15, 2014 1,022 137 May 19, 2017 #1 I know on dahua nvrs you can setup continuous and motion detection at the same time. Is that possible with Lts or hikvision?
alastairstevenson Staff member Oct 28, 2014 16,473 7,231 Scotland May 20, 2017 #2 Try a search, there are a few posts about this, for example : Updated NVR firmware published - NVR_78_79_EXX_V3.4.80_160718.zip Reactions: techsaurus
zero-degrees Known around here Aug 15, 2015 1,335 849 May 20, 2017 #3 pal251 said: I know on dahua nvrs you can setup continuous and motion detection at the same time. Is that possible with Lts or hikvision? Click to expand... Yes it is possible on both Reactions: techsaurus
P pal251 Getting comfortable Mar 15, 2014 1,022 137 May 22, 2017 #4 Anything special besides putting setting up continuous and motion recording at same time? I'll try it again.. Thanks for the"search" suggestion.
