- Sep 23, 2017
- 5
- 2
I currently have a Hikvision DS-7616NI-E2 (firmware V3.4.103 build 181226) and have 5 cameras (Hikvision bullet, dome, dahua bullet, dome). The system works well but I could never get the motion detecting to work correctly. The cameras are all outdoor and small things trigger motion, like rain, snow, shade. It got to the point that I just disabled it and never bothered to use it. I tested every possible setting through the web GUI. Another issue with the NVR is that the small fan makes so much noise that I started to look at finding a location where it will not be in my office.
I have tried Verkada and Google nest cameras at other locations and they seem much more advanced in the detection. I was looking for suggestions on systems or maybe just a DVR upgrade if the newer Hikvision are better. Having a system with better motion and line detection would be great.
