Hi everybody,
I was wondering if any of you guys know a VMS under the format of a OVA to deploy into VMware/etc or simply an ISO image to create a virtual machine on my server.
I am currently using NetCam Studio 1.7.0 (which is super easy btw, by far the most stable VMS I used) but it is hard on system ressources; Currently 8x 720p cameras connected to it and CPU usage is pretty high and I allocated 4 vCPU...
I have tried several linux alternatives but I didn't like them as I love Netcam Studio. Also tried Blue Iris but seems to be the same on CPU usage and didn't get the chance to try the D2D function as I was on the demo.
I tried Bluecherry ISO (2 different versions) but had log in issues, etc. Also tried C-Mor appliance which is the kind of thing that I am looking for, an OVA appliance to deploy into my VMware home lab ready to go and easy on ressources.
Finally I found the NVR from DAHUA NVR4108-4KS2 which is pretty cheap and seems to be a good alternative. I'm just scared it won't work with my Onvif cameras that I have right now. Chinese supplier say it will but will the built-in motion detect from the NVR work with my cameras? I would like to just try the software before buying the actual NVR so I can test it before buying
I don't know what to think now.
I have everything on a custom server build with free ESXi 6.7 with a E3-1270 CPU (4c/8t) and I have the VMS virtual machine and also my PLEX virtual machine on this physical machine so CPU is pratically always at 80-90% with users on PLEX, 50% with PLEX off.
Thanks guys
Mickael
Thanks guys
Mickael
