Change it to static and assign it a number on the same IP subnet that the ethernet port is.
thank you very much for the help.Change it to static and assign it a number on the same IP subnet that the ethernet port is.
my computers ethernet is all that with 1xx at the endWhy the 169.254.137.2 IP address for the cam?
IIRC, that's the range you get when a device is set to DHCP (not static) and there is no DHCP server available or responding.![]()
ill get itWhere is the top part of that pop up window - that will show the error it is throwing.
no luckCopy this into where it says main:
Code:/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
You probably should change the IP range for things but get it working first.
thanks. I found the optimizing blue iris threadWhat you'll also want to do at some point is to copy that same string into where it says Sub. Then change subtype=0 to subtype=1. That will be the substream for the cam. Read up on substreams. Using that will cut down resource requirements in BI a lot.
