Latest firmware for SD42212T-HN?
tomas21
Aug 12, 2014
175
24
US
Can anyone tell me where I can find the latest firmware for the SD42212T-HN ?
why? what problem are you having
Unit has been very unstable lately and some text changing to Chinese. Reset defaults but hasn't improved.
Wanted to flash with latest firmware to see if that resolves the issue. All other cameras are fine.
Is your SD42212T-HN camera constantly losing connection and rebooting?
Mines kept getting worse especially in hot weather until it wasn't coming back by itself and I replaced with another. 2nd one is doing it about twice a day now even in the weather in the Northeast and I believe same is going happen to 2nd unit.
I'm running it with poe+ and firmware is 2.210.0000.6.R, build : 2013-11-13.
you mean 24VAC? I dont think this takes 12VDC according to spec sheet
I just upgraded my firmware with the following: 2.422.0001.0.R.T4.1216.3N.NR, Build Date: 2016-11-02
The menu issue and stability in the camera is resolved. IVS features are working as expected.
Reactions: nayr
gotta link for that? anything that fixes stability issues would be good to share.
I have two SD40212S-HN on a site with the identical 2013-11-13 FW to tomas21. All the vertical presets on one of them periodically becomes corrupted, dropping down by around 45 degrees. I was thinking about replacing the 80 metres of Ubiquity tough cat5 to it but but now would first prefer to update the FW. So, it's either nayr's version or tomas21's but having clicked on tomas21's Dahuawiki site link am not clever enough to know which to choose. Also, will a FW update work OK over slow broadband if there are a few errored packets without disastrous results? Any help please?
I have this same model too.
Would love to get the latest firmware. Can't log in to the DahuaWiki to get the firmware.
Perhaps someone can post?
