- Nov 25, 2016
- 265
- 274
Tinkering with my Dahua 5216. Found while setting trip wire up that I don't need to enable motion detection also. Otherwise it will alarm with any motion detection on screen. The regular motion detection stops with me walking at about 150 ft away. For the trip wire I made the maximum box about twice the size of a car, minimum box was about as small as I could get it, with trigger direction going up the drive. I discovered that the event log (only on the local NVR) shows a list of trip wire events with a play button. The smart PSS and config tool didn't show the detailed log. First time messing with it, didn't mess anything up . On the 2nd image I was backing up the driveway to trigger it.
