I have a Dahua IPC-HDW2231R-ZS camera (2mp starlight varifocal). In setting up IVS intrusion I am able to set the minimum size of the object. I selected "Min Size" and "Draw Target", which resulted in the blue-ish box you see near the middle. It looks fairly square, but below it resulted in a rectangle of 236x419:
If I go to the pixel counter and enter the same size it shows up much bigger:
The pixel counter makes more sense since it's a 1080p camera (1080 pixels vertically, versus the 419 shown). I also can't enter the size values manually, which is annoying. Is there a fix for this or do I need to do trial and error until I get the pixel (but not visual) size I want? Thanks!
