I have a few IPC-HDW5231R-Z with 256gb Sandisk microSDs.
I have been reading through the forum and trying to find more information about the frames skipping when there is an IVS event. Most of the posts are talking about skipping when using a NVR. So I decided to just use the cameras with internal microSDs. Come to find the issue exist when recording on board as well. It is very unfortunate considering IVS event is the time when everything should work fine...
The cameras around my house are skipping exactly when a face is supposed and should be seen.
This is my question:
Is anybody else experiencing the IVS skipping when recording directly to onboard microSD?
Any way to fix that issue?
Is buying a certain NVR with certain firmware going to help?
Thanks
Thanks
