iVMS-4200 play multiple recordings syncronized at once
mlapaglia
Getting comfortable
Apr 6, 2016
860
513
Does iVMS-4200 have a way to play recordings from multiple cameras at once, all controlled from the same slider?
Someone was walking around the front of my house today back and forth across 4 cameras. I would like to be able to watch the stream from all 4 cameras at once, instead of having to jump around to each camera and hitting pause/play.
Nevermind just need to RTFM http://www.faps.com/download/IVMS 4200 Client Software USER MANUAL.pdf
3.2.3 Synchronous Playback Purpose: In synchronous playback, the record files can be played back in synchronization. Note: Record files from up to 16 cameras can be played back simultaneously. Synchronous Playback for Some Searched Cameras Steps: 1. Start the normal playback of the searched cameras. 2. Click in the toolbar, and then the record files in normal playback will be played in sync. The icon turns to . 3. To disable the synchronous playback, click the icon . Synchronous Playback for All Searched Cameras Steps: 1. Search the record files for the normal playback. User Manual of Hikvision iVMS-4200 v2.0 37 2. Click in the toolbar to enable the synchronous playback. The icon turns to . 3. Select the record file from the list and click , or click on the timeline to start the synchronous playback for all searched cameras. 4. To disable the synchronous playback, click the icon .
