- Jul 12, 2015
- 79
- 40
I have an issue with our RS-485 jack on the back of our DVR and I don't know why it's not working. I'm hoping somebody can give some feedback to help me resolve this issue.
I was under the assumption that the RS-485 port was defective on the DVR. Using my camera tester, I determined the cable and camera is fine as I'm able to turn and zoom with no issues.
When using my voltmeter, I was getting power spikes from the RS-485 jack on the DVR. That seemed to indicate that the RS-485 port was good, but I went ahead and assumed that maybe it was defective since the PTZ worked fine on my Tester, but not on the DVR.
After all that, I swapped the DVR with a different Everfocus DVR we had in storage but that didn't resolve the issue. Can't imagine 2 DVRs having bad ports and I'm confident all the settings between DVR and Camera are correct.
Would it have anything to do with the RS-485 port on the DVR also having a Ground slot? There's no ground wire on the camera itself for RS-485, but would it need to be grounded from the DVR side?
I'm used to only having a positive and negative, but this DVR has a positive, negative, and ground.
The DVR is an ECOR264 9x1
