Hi all,
I would like to try and integrate a driveway beam alarm with an IP camera and NVR to create a bit of a security system in my yard to see what cars enter my property.
I have bought the driveway beam alarm in the following link:
1B-60 Wireless Driveway Beam Alarm | Ultra Secure Direct |
It consists of two beam alarms either side of the driveway into my house and a receiver that is plugged in inside my house that rings when the beams get interrupted. The receiver has time adjustable N/O or N/C Relay outputs.
I would like to buy an IP camera to monitor my yard, and a NVR to continuously record the footage to a HDD.
I would like the system to operate something like this:
I don't want the PC monitor/TV to be left on needlessly so that's why I only want it to power on when a car has been detected by the driveway alarm. I also don't want to have to use a remote every time to do this.
I think through the use of a Raspberry Pi or Arduino I could probably achieve my goal (With a lot of work), but I was wondering if anyone knows of an NVR with I/O connections that can be connected to the driveway alarm receiver to achieve what I described? Such a thing may not exist or be possible but before I undertake anything I wanted to make sure there wasn't an easy way around it as I am not experienced with Cameras and NVR's.
Also would appreciate suggestions for an IP camera that is minimum 4MP and good value for money. Doesn't need to be fancy or rotate as it will be mounted facing in a fixed direction. Only really needs to be clear enough to read registration plates from about 10 m away.
Thanks
- Vehicle enters my driveway, beam alarm gets interrupted and receiver rings.
- A PC monitor/TV which is connected to the NVR via HDMI powers on/wakes from sleep when the beam alarm receiver rings.
- PC monitor/TV turns off/goes back to sleep after 1 minute
- NVR is still continuously recording the footage to the HDD while all of this happens
Thanks
