Hi all,
I have this camera (IPC-HFW5231E-Z12E) and want to set a slightly different zoom during the daytime schedule (since the LPR is much easier during the day and I would like the larger FOV to see other objects/areas),
I am able to manually zoom & focus in both web browser camera configuration setting and in BI v5. HOWEVER, I cant seem to set the ptz presets in blue iris, and there is no option to do this in the web browser either (camera current firmware is from mar2019). In Blue Iris ptz settings I am using 'Dahua New V4', which seemed to be the only one that would respond with zoom/focus/IR commands.
Any ideas? I've seen some of the HTTP commands for other cameras, but am not sure how I can set this up or even test the commands. Can I just save 2 txt files with url commands and call those files on my schedule? Or can i update the firmware without bricking it, and get this ptz preset capability in the web browser?
Thanks for the help,
C
C
