Hello,
I am new here and have already read a lot in this forum. I also have read about where to buy and where not to buy via aliexpress. Unfortunately, I already have bought a camera over DragonEye and don't know if it is crap or not.
Here is my problem. I have a new NVR NVR4108-8P-4KS2 purchased from Empire as recommended here. From then on, I thought everything would be better in regard to IVS and then mentioned camera above. I learned that the NVR has nothing to do with how the IVS works because the camera does all the work. I set up IVS -tripwire- also I activated IVS in the smart plan settings. I set the max in min target. I took my laptop and walked out the door. The green frame showed up and the tripwire went red. Then I did a again and nothing happened. What I want to say is, sometimes it works and other times it doesn't. It does not function in a way I can rely on. Does anyone have an idea what I can do or did I buy a cam which is not working properly? Would another firmware help and if yes where can I download it or is that too risky, since I bought it from aliexpress from a seller I don't know if I can update it or not because I could end up bricking the camera.
The same issue I have with a SD29204T-GN where IVS does not work. I also bought it from DragonEye.
I appreciate every help.
Thanks Alex
Thanks Alex
