The IPC-Color4K-T180 uses the PFB203W bracket. I have modified some brackets by drilling additional holes in a non-recommended bracket, but sometimes the camera is too large for the application. Not sure if the 205W can be modified to fit this camera. If you can find the specs on a diagram of the camera, you can measure the hole spacing and match it up with the diagram for the bracket to see if it will work.
