- Mar 10, 2014
- 717
- 203
Sort of an odd comparison as you would think they are the same except for processor, but no. They look the same, have the same slot for a 2.5" hard drive, same dimensions. What the Celeron NUC has is WiFi (plus Ethernet) and a full size HDMI port (i5 has a mini HDMI so you need an adapter), it also has a 12V wall wort power supply vs. the power brick with the i5. It only has one RAM slot vs. 2 on the i5. Also has 3 USB ports vs. 4 on the i5.
I put it on my Kill-A-Watt meter and at 100% CPU doing updates, it was using 9.5-10.5W. Stop doing heavy CPU intensive stuff and it drops to 8W like for a web browser. It's actually pretty responsive, way better than the old Atom processors. I put 4GB RAM and a 250GB SSD drive I had lying around. Cost me $130 for the NUC, $31 for the RAM and SSD already had. Put 64-bit Win7 on it.
I'll let it get all the updates before I install Milestone XProtect Go on it and load up some cameras on there. If that does well, I can try BlueIris. When done playing, going to replace a Tivo with it. I needed the Tivo somewhere else. What's cool is it has a IR receiver built-in like it was made for that purpose. When you think my Tivo uses 35.5W and this is 10W, that's big savings, about $80-90/yr in power costs in my neck of the woods.
