MrBlackops88 n3wb Nov 19, 2017 6 0 Dec 22, 2017 #1 What laptop brand, configurations, and hardware do you guys recommend for installers, and ones who run these cms applications constantly?
S SantiagoDraco Getting the hang of it Dec 8, 2017 130 51 Dec 22, 2017 #2 Not nearly enough information to make a proper suggestion. Budget? Use (indoor/outdoor?) Simple answer is to get a ruggedized if you'll be working outdoors.
c hris527 Known around here Oct 12, 2015 1,847 2,222 NY Dec 22, 2017 #3 MrBlackops88 said: What laptop brand, configurations, and hardware do you guys recommend for installers, and ones who run these cms applications constantly? Click to expand... I use a Dell Latitude Rugged ..worth it if you are using outside all the time, the screen is better than my panasonic toughbook.
