Image quality of IPC-HDB4300C via NVR4104P - night time
psycik
Dec 9, 2015
230
43
Wellington, New Zealand
I've go two cameras hooked directly to a NVR4104p and one that the NVR considers remote (which means you can still access to its web page directly).
I've found since running all footage from the NVR that darkness is not dealt with anywhere near as good as it was when the cameras were independent.
Is there anything I can do to brighten them up?
Here's two. The Garage One (right on my screen) was from when the camera was independent. The left is from the NVR.
Enclosed are the Image settings.
Something is changing the settings (maybe when you are in the NVR by accident?). The stream saved by the NVR is identical to the stream saved by the camera.
How are you getting the screenshots? You're not screenshotting your screen are you?
Screen shots are sent via FTP to a server I have (then uploaded to google photos).
I do have Smart PSS running, but it shouldn't be doing anything actively on the cameras.
Hm, I have noticed that accessing this camera via the NVR I don't have as many options to play with the exposure settings. Where if I access the camera directly, I can set manual exposure and up the gain (which I believe I did have in place for that independent picture in my OP)
