Cant get into that link, but Yes,The HiK Colorvu along wiht the Dahua equivalent that have white light LEDS providing white light are an option and yes known around here. Search you will find reviews.
This camera uses the same 4MP 1/1.8” sensor as the 5442 models do (including the “Full Color” 5442TM-AS-LED model that has LED lights like this Hik ColorVu).Ahh, this is the comparable to the 5442? I hadn't realized it required the "always on" LED. If these could be kept off and only turned on through some API call from BI when motion is detected, would you agree this would be better quality than IR?
This is a fixed lens version of the 2231-Z with good night vision. You might need to check a few sellers on Ali to see if they have stock.
Not tried it but do have a couple of the Z version (2.8mm - 13mm lens) on order.
#Aliexpress US $63.12 13%OFF | Dahua IP Camera IPC-HDW2231TM-AS-S2 2MP WDR IR Eyeball Network Camera Starlight built-in Mic support POE Security Camera
I can only speak for a few of the cameras I've opened up. Changing the focal length requires changing the lens assembly. Removing the adhesive and turning the lens in its screw mount adjusts the focus.It appears you can open a fixed focal camera, remove the epoxy glue around the lens cap, and screw it in or out to manually adjust the optical zoom ... is this true?
No, that would only change the focus.It appears you can open a fixed focal camera, remove the epoxy glue around the lens cap, and screw it in or out to manually adjust the optical zoom ... is this true? If so, this would allow a person to re-purpose one of these cameras, adjust the optical zoom, and not have to worry whether the camera is suited for the new location. For me, I don't adjust the optical zoom but would if I moved it or had different needs in the future.
You can see the differences here: Dahua Technology - Leading Video Surveillance Solution Provider with CCTV ProducAre there any Cliff Notes with the differences between Pro and Lite? I only seen a thread for NVR Pro vs Lite...
Hi @essjay
I don't think "knock off" is an appropriate concern, however always do be cautious with Aliexpress vendors - as often they will sell a Chinese market camera from Dahua / Hikvision and "hack" the software to provide English language support. So do watch for that... and try to only go with vendors which other ipcamtalk members will recommend.
 so ordered one to take a look. I didn't see a comparable model on Andy's Aliexpress shop or would have ordered it there.
 so ordered one to take a look. I didn't see a comparable model on Andy's Aliexpress shop or would have ordered it there.Have you gotten your camera yet?I contacted the China Top Security vendor and they stated it's English/international from the Dahua factory and upgradable firmware.
Curiosity is killing meso ordered one to take a look. I didn't see a comparable model on Andy's Aliexpress shop or would have ordered it there.
