IDMSS 4.70.001 Playback issue
TechBill
1,829
1,190
Is anyone using IVS notifications alert (now called messages) and after you open the alert then hit playback - does it playback the opposite daytime hour of the alert time?
Like you get an alert at 3:15 PM then hit playback and it play back you the 3:15 AM recording. (Notice the AM)
I am testing the latest NVR firmware but I can’t tell if it coming from the iDMSS update or NVR firmware because I had alert turn off until today which I noticed the bug.
Anyone else experiencing this bug with latest iDMSS?
Thanks
Look this is bug only happen if you set your camera / nvr to use the 12 hours format. When I switch to 24 hour format then it playback the correct recording timeline.
Reactions: toolazyforalogin
