I7-8700k still the best budget friendly option?
Afranze
Nov 17, 2022
93
14
Geelong
Hi
Been browsing eBay and the hardware guide on this forum for CPU models
Just wanted to check if people think the i7-8700k is still a good option with plenty of longevity for
8 x 4k poe cams ? Or is there affordable 9th Gen out?
It was last updated around 6 months ago
Thinking it'd time to update my cameras to 4k but would get the PC first
Will look on eBay for pre owned dell optiplex or hps
I also want to have space for my 3.5 inch purple drive
Also is a graphics card necessary?
Happy new year all !
Hi
i8-8500 also seems good ..
the 9th gen really are not much better .. 12th gen is really where they get a lot better
Hi
It all depends on the price relative to newer machines... an i5-11500 is more powerful than that processor..
Reactions: JDreaming and Crows
My 2 cents on the graphics card.. My nuc-like i5-11320h and its integrated Iris Xe does a great job handling Blue Iris / Code Project with 5 IPC-T5442T-ZE cameras. The cpu is barely used unless I am on the pc playing a game or watching youtube. The iGPU is doing most of the work related to BI and the AI.
I suggest trying the iGPU before splurging on a gpu. Put those funds towards a newer processor/iGPU ;)
There are some extremely good processor comparison resources around. One is on the Intel website, and there are numerous other independent ones. I didn't bookmark them, but it didn't take heaps of searching to find stuff either.
I think one was simply CPU Benchmark.
Thanks guys
any recommendations to run BI with 8 x 4k cameras?
In terms of what to look for, imho get a case that can hold at least one 3.5" HDD and SSD .. ideally one that can hold 2x 3.5" HDDs .. ram is super affordable now, so I start with 16GB on the PCs I buy ..
Also note, some Dell and other brands of machines use "sleds" to hold their HDDs .. so if the model is listed to hold 2 HDDs and is sold only with one, then you may need to buy another "sled" to hold another HDD
Yeh I definitely need a space for one local 3.5 inch HDD
Just need to decide on CPU
I think for budget affordability the i7-8700k is still a good option
I have not seen Dell or hp used business class machines come with the i7-8700k chip .. only the i7-8700 .. or i5 i3 versions .. the i5-8500 I see more off than the i7 when I search
