Hi all,
I recently bought Dahua NVR to replace the now defunct Cleverloop system but can't find ANYTHING online about it?! It's a Dahua NVR2108HS-W-4KS2 and the latest firmware 3.216.0000000.0, Build Date: 2018-07-05
I am still using the same Cleverloop IP camera's over WIFI and they show up fine in the NVR but nothing seems to work with the NVR in relation to Motion Detection. Pulling my hair out setting everything up and reseting everything up but it simply won't trigger even with the regions setup per camera via the NVR and MD enabled with 24 hour active.
The only thing I can think of is that the NVR needs a firmware upgrade or the camera aren't compatible? If it's NVR related, where can I find a more recent version than 3.216.0000000.0 as nothing on the Dahua site? If it's camera related, I thought MD would run on the NVR once a camera signal in present over Onvif? The whole reason I got a Dahua NVR was because I heard Onvif based cameras would work so I wouldn't have to replace them too.
Appreciate any help you can give!
Al
Al
 Is there any other way of checking if the Cleverloop cameras produce ONVIF motion events?
