Hi,
I'm trying to stream the main video feed of my new camera (IPC-EBW81230 12MP Panoramic Network IR Fisheye Camera)
I want to stream in the game engine Unity.
I was able to get the stream into OBS Viewer software by using the rtsp protocol with the following URL:
But I need the HTTP equivalent to get that feed into Unity. I already have the
I have tried the following url with no luck:
It returns me no bytes of information and stops...
I couldn't find any doc on that...
I'm using this code to get the stream:
Anyone has an idea?
Cheers,
rtsp:/admin:<password>@192.168.0.50:554/But I need the HTTP equivalent to get that feed into Unity. I already have the
http://admin:<password>@192.168.0.50/It returns me no bytes of information and stops...
C#:
using UnityEngine;
using System.Collections;
using System;
using System.Net;
using System.IO;
public class NetworkCamera : MonoBehaviour {
public string sourceURL = "http://192.168.0.50";
private Texture2D texture;
private Stream stream;
private MeshRenderer frame; /Mesh for displaying video
private void Start() {
frame = GetComponent<MeshRenderer>();
GetVideo();
public void GetVideo() {
texture = new Texture2D(2, 2);
/ create HTTP request
HttpWebRequest req = (HttpWebRequest)WebRequest.Create(sourceURL);
/Optional (if authorization is Digest)
req.Credentials = new NetworkCredential("admin", "<password>");
/ get response
WebResponse resp = req.GetResponse();
/ get response stream
stream = resp.GetResponseStream();
StartCoroutine(GetFrame());
IEnumerator GetFrame() {
Byte[] JpegData = new Byte[100000];
while (true) {
int bytesToRead = FindLength(stream);
print(bytesToRead);
if (bytesToRead == -1) {
print("End of stream");
yield break;
int leftToRead = bytesToRead;
while (leftToRead > 0) {
leftToRead -= stream.Read(JpegData, bytesToRead - leftToRead, leftToRead);
yield return null;
MemoryStream ms = new MemoryStream(JpegData, 0, bytesToRead, false, true);
texture.LoadImage(ms.GetBuffer());
frame.material.mainTexture = texture;
stream.ReadByte(); / CR after bytes
stream.ReadByte(); / LF after bytes
int FindLength(Stream stream) {
int b;
string line = "";
int result = -1;
bool atEOL = false;
while ((b = stream.ReadByte()) != -1) {
if (b == 10) continue; / ignore LF char
if (b == 13) { / CR
if (atEOL) { / two blank lines means end of header
stream.ReadByte(); / eat last LF
return result;
if (line.StartsWith("Content-Length:")) {
result = Convert.ToInt32(line.Substring("Content-Length:".Length).Trim());
} else {
line = "";
atEOL = true;
} else {
atEOL = false;
line += (char)b;
return -1;
Anyone has an idea?
Cheers,
