HP Elitedesk 800 G1 SFF onboard video card died....
wantafastz28
Getting comfortable
Nov 18, 2016
551
253
Phoenix, az
Anyone have any ideas on what the best solution is to fix this? Whole new motherboard, or is there a intel video card i can use to replace this? I also use one of the display ports for video out.... Frustrating problem to have right now! @fenderman
Your onboard video did not die..i can assure you about that...what problems are you having?
Is anything displayed on any of the computer's video outputs when you first power it on?
Be sure to try different cables and monitors.
I suppose I should double check that... it is cutting out via rdp as well...
Verify PSU output voltages are what they should be and are nice and stable. Clean / remove dust, verify all fans are operating properly.
I had a fan bearing seize when I was out of town on a 100+ degree day a few years ago, deep fried several hard drives.
Run a RAM test.
Reactions: wantafastz28
Run a RAM test.
If the video is cutting out via RDP there's likely a software problem
I hope so, no more free time to tinker with stuff after addition to the family. Grrr. Thanks guys. Will let you know what it is.
W
Back up and in business... I suppose some updates were due, hasn't been restarted since December... I still need to address my heating issue now that i got back into that rack... fun fun
