How to enable all smart plans? (and other minor issues on the 5442 turret)
Arjun
10,757
14,082
USA
It appears I'm not able to have all smart plans run concurrently on the 5442 turret (IVS, Heatmap, and People Counting). I'm only able to enable one smart plan at a time. Currently have it set to IVS. I can enable People Counting and Heatmap through other menu options, but the camera doesn't actually activate these plans, thus no people counting data available.
Also am unable to set the correct time zone, although time is showing correctly on the camera it defaults to Cambodia
Ive had occasion where a camera didnt want to save settings, I just keep hitting save/refresh 2-3 times and clicking away from that tab and coming back to verify and it eventually does save.
Reactions: Arjun
I had that issue as well, so I hit save and then hit refresh and that fixed it!
This is bad, it still defaults to this time zone
Also I know there is no difference between NTSC and PAL, but I can't even save the format as NTSC, after rebooting it stays on PAL, lol
And stays on Outdoor priority as well in-spite of hitting refresh multiple times and rebooting
I feel like since Day 1 I've had problems with the 5442, still have memories of loose balls (trying to exhibit some humor here :p). At minimum I've been impressed with snappy performance on the Web UI and IVS, and and overall nightime picture quality. However with a 6mm focal length, my 2mp Starlight 4231 turret does a better job with maintaining overall sharpness than my 6mm 4mp 5442 turret, I can make out the characters on license plates and facial features very well with the 2mp model (24/7)
Also microSD card has been wonky (camera doesn't even record to it, it recognizes it but doesn't format and read and write and there are no SD Card errors as per the logs), I'll be replacing my microSD card before jumping to conclusions, might even just perform factory reset to omit all possibilities
My favorite camera of all time is the 5231 varifocal, lol
Set date format
Time formst
Time zone
save->refresh 3x in a row
Reactions: Arjun
So far its maintaining it now. However, I'm sure if I reboot it will revert back to Bogota
Hopefully not a placebo effect, lol
Set date format
Time formst
Time zone
Still showing shutter priority not able to set it to Auto
Odd... check your profile, set it to “Schedule” for now, make sure you set the day /night slider, and try again with the 3x save/refresh
Reactions: Arjun
Thanks, the settings seem to be sticking for now, so that's a good thing :D
Everything seems to be working fine now except for being stuck on Shutter Priority. However, I have this funny feeling that it is related to the firmware update (V2.800.0000000.10.R, Build Date: 2019-11-18 )
I remember @wopi82 sharing his feedback related to exposure settings and essentially fixing the SmartIR issues that originally came with the 4mp 1/1.8" sensor cameras. This firmware seems to default to Shutter Priority instead of Auto to compensate on the issue
Doesn't seem to be applicable to the turrets
I just did the first reboot since yesterday and the camera reverted back to Bogota Time zone and PAL format, LOL
What's up with the 11/18 firmware? :facepalm:
hmmm never had an issue with it.. :idk:
