how to add hikvision cameras to an dahua nvr?
wozzzzza
Pulling my weight
Jan 5, 2015
485
111
upgrading the NVR from a 16ch hikvision with a mix of 16 IP hikvision cameras to a 32ch dahua NVR NVR5232-16P-4KS2E with 16 Hikvisions IP cameras and 8 dahua cameras.
dahua have connected no problem a couple of the hikvision ones have connected ok as well but cant for the life of me get the others connected.
for instance the ds-2cd2165g0-i hikvision camera, cannot get the DVR to display the video output. it says it is active but you cant add it, but you can see it on the computer ok and bring up video in a browser.
any one know whats going on here??
in picture you can see the status with green tick but when i ass it the status is red and wont show image.
You may have to log into cam's webGUI and enable ONVIF support.
You may have to log into cam's webGUI an enable ONVIF support.
i googled and found it, did what it said, set the user and password in the hikvision-cgi section as the same as the login to the camera and still nothing.
i find the enable onvif doesnt save though
