Hi guys, I have a customer that is looking for a pc to handle 80 cams at a "club". They are watching and controlling the system constantly. Anyone have a ballpark what this will cost to have someone build it? He wants better than the 128 channel NVR I recommended.
Can you say what you have planned ? Some installers fail with that many cameras on one system.
Its not only that your system must be capable to encode all streams at the same time, ...
you have also think about recording. dahua has the ability in their 128channel device to put several harddrives in. but i am not sure if you can decide which camera record to which harddrive or if it only possible when they are in a raid.
raid should be avoided at anytime. if ONE drive fails and you exchange one drive, the system start to rebuild and slow down anything.
seagate skyhawk are rated for a maximum of 64 hd stream recording. And in my opinion (i never found a statement about that) they are talking about 1080p streams.
if you are dealing with 4mp(2k) @ min. 8mbit stream cameras, then you will be not able to have that many cameras on one harddrive. even 4 harddrives with 80cameras can be worse if you want to playback while recording.
its not only recording. the next problem start if you want to playback while recording. read/write at same time is the hardest part for any harddrive.
start reading here:
Explore the Seagate Blog for expert insights on data storage, AI, edge computing, security, and cloud with trends, tips, and solutions shaping the future of data.
blog.seagate.com
what is the result? lost frames. either on playback OR worser on recording.
So if you want to record that many streams on ONE device and also be able to use AI / playback / ... you should go with nvme drives. they can handle the massive load. even normal "ssds" struggle with random read/write activity.
i am not sure if
blue iris can handle it...maybe it will struggle... but it depends what you want.
i am not sure if blue iris gpu version can use more than 1 gpu and use them all. then it should be no prob at all.
Then it comes to networking... you need 2-3 poe switches with 48ports which can handle the power load of all cameras... they are not cheap at all and you should not try to save there because some of these "budget" poe switches fail when there is load at limit.
