Ok,
I am vaguely familiar with the process of what i am trying to do. but it is refusing to cooperate. SO that leads me to believe i am missing one piece of info.
Here is what i have:
Location 1
Hikvision DS-7608NI Q2/8P with 4 cams (DS-2CD2143GO-!) attached hard wire to port 1-4. All good
Location 2
4 cams hard wire attached to a poe switch with static assigned IP's and ports open on router and all that. They work great going directly to them AND using iVMS-4200 off site.
Heres where it gets whacky.
When i manually add them to the remaining 5-8 ports, even tho i change the management port when adding (8001, 8002, 8003 and 8004) to match what i put on the cams (also what i put into iVMS-4200 btw) ALL 4 of the cams show the cam that is on 8001.
I feel like it is a routing issue, but the Upnp shows everything is good and valid on all 4 and in the router AND i can hit each of them individually off site using explorer.
what am i missing?
thank you for any help.
David
Location 1
Location 2
what am i missing?
David
