I am helping out my neighbour with his camera setup. As he had problems with his installer after asking for his login credentials, to install extra camera's, I convinced him I am a nerd expert with these gadgets.
He has a Hikvision DS-7608NI-K2/8P with 5 Hikvision IP-camera's. I have installed 2 extra Dahua IP-camera's and a Reolink 2K+ videodoorbell PoE (5 MP). It works like a charm every time when I leave his house. They record and can be seen live on Hik-Connect app.
The problem
After an unknown time, between 1 day and 1 week, the Hikvision NVR resets my (ONVIF) IP-camera login credentials (username nvr and password DrieXr@den#R) from the Reolink 2K+ videodoorbell, in the Hikvision NVR software, to default username admin and password 12345. So, obviously it does not record anymore on the NVR and cannot be seen in the Hik-Connect app. It can still be viewed directly via the Reolink app as the login credentials there remain thesame, as it should.
Things I have tried
Giving in to the bug(?) and changing the login on the Reolink videodoorbell to admin with 12345 cannot be done because the Reolink software needs at least 8 characters.
Only 2 Hikvision camera's are connected to the NVR PoE ports. All the rest via seperate PoE switches.
Anybody has any idea what I can do next?
The problem
Things I have tried
- Changing the username and password in the IP-camera settings on the Hikvision NVR, several times. Even to username admin, with a different password (not 12345). It reverts again after a few days to password 12345.
- Updating the Hikvision NVR firmware from 4.74.200 build 230522 to 4.74.205 build 230712. After a few days, it reverted again to username admin and password 12345.
- Deselecting a checkbox I found somewhere in the Hikvision NVR config that allows IP-camera password changes. After 1 day it reverted to the username admin and password 12345 again.
But, it is worth a shot, I will try that first thing next week when I am back at home.
