Hi,
I have a HikVision NVR model DS-7616-I (this is a model without PoE port).
All my camera are plugged into a PoE switch.
I created a VLAN only accessible by NVR where I plugged all my cameras and made the NVR accessible via my normal LAN. (camera IP 192.168.2.X, NVR IP 192.168.0.100)
So in other word, all camera are only visible by the NVR.
I was hoping to use the Virtual Host feature of NVR to access camera from my LAN (via NVR), but when I select this feature, the Connect link that appear in camera list is the ACTUAL IP address of cameras on VLAN (192.168.2.X and thus not accessible). The NVR does not look do to it's Virtual Hosting job (i.e. create a link like 192.168.0.100:65001).
There is no option either to configure each camera port for virtual hosting.
So does the DS-7616-I actually support Virtual Host or is that option there for nothing ?
Thanks
Thanks
