Hikvision NVR, cant seem to add a dahua camera
wozzzzza
Pulling my weight
Jan 5, 2015
485
111
new hikvision nvr ds-7732nxi from andy and couple year old dahua camera im trying to add and it wont add saying incorrect username or password
i can log into the camera with my browser using the same username and password im entering into the NVR but it just wont connect to it
any ideas??
Is it too much to ask that you rotate a couple of phone images before you posted them? Makes my neck hurt.....:cool:
If you adding Dahua cams using ONVIF protocol, you must enable ONVIF and create ONVIF user/pass (usually the same as main one) on cam...
ok, will give a go tomorrow, just weird this particular model dahua is doing this and the other few, different models, i have put in there went on fine.
you were all wrong in a way, i was going through the settings looking for onvif and found the ip filter for trusted sites was enabled and only the NVR and my comp IP was in trusted, so i added the new NVR IP and connected straight away. no idea why this trusted site thing was enabled in first place.
