Firstly Port forwarding isn't the best option, VPN is the preferred solution. Having said that and if you insist, I don't think you should be doing any NAT configuration on the NVR's themselves, the port forwarding should be done on the router. Create 2 rules/services (or multiple rules for the ports required), for each of the NVR's to point to their internal fixed IP addresses. Having different ports configured on the NVR's as you have is good so the router can redirect incoming connections correctly.
Then try something like Open Port Check Tool - Test Port Forwarding on Your Router
The tool will help confirm whether your ports are open.
When connecting with your smart phone you need to provide the correct (different) port numbers for each of the connections (NVR1/NVR2) in it's configuration.
