I'm thinking about getting a NVR to replace my current Synology Surveillance Station setup. I don't find Surveillance Station easy enough to use and the app support (iOS) is not 100% reliable.
I currently have four cameras, one Hikvision DS-2CD2142FWD-IWS (English version), one 2MP Huisun mini 10x PTZ and two D-Link 932L. There will most likely be a few more Hiks in the future to replace the D-Link's. Network-wise, my current setup is a mix of wired (Huisun) and wireless (Hik & D-Link) cameras
My questions.
1. If I get a Hikvision NVR with POE-ports, for example the new DS-7600NI-I2/8P, must all cams be connected to the POE ports of the NVR or would a setup like the picture below work? I.e, can a NVR with POE handle cameras connected to the router or to a switch in the network just as well as cameras connected directly to the NVR?
2. If I get a Europe/Western Region NVR, can it be used both for western and china (brown box) versions of the Hik cameras? Or does western region cams only work with western NVR's and the other way around?
3. Does the Huisun mini PTZ work with Hikvision NVR like the DS-7600NI-I2/8P or is that camera only supported by some specific Hik NVR's? I've seen mixed results in this forum when people tried to connect the Huisun with a Hik NVR.
Many thanks for a great forum!
dala
My questions.
dala
