Hi guys I have Hikvision iDS-7116HQHI-M1/S - DVR running on 4.7x firmware currently and its password locked. I followed the guide for flashing new firmware but no luck i can't get passed HKVS $ no command is taking setenv ';update' or ';printenv'. I was wondering if someone can help me with this. Here it's the output of putty when i send the commands.
NDD>XSAT
UNZOK!PCK[120]
table1
DRAM1_DDR4x2_2400_32B ini_ver: 0x41210723
zq_trim[e], ldo_trim[8]
CPU1200 DONE
DRAM2_DDR4x2_2400_32B ini_ver: 0x41210723
ddr2 zq_trim[d], ldo_trim[6]
ddr init done
HVYOK
UNZOK!
Loader Start ...SPI NAND MID=000000C8 DEV=00000051
bin_size: 0x00008140
sha256_align_size 0x00008140
atf.bin RSA ok!
check sum ok!
sha256_align_size 0x000A9080
uboot RSA ok!
smp(bl31)
$$$64wfi6644wwfifi64core2_jump_program 0x002065F3
64code2JumpCodelen 0x0000018C
ARC64warmrstwarmrswarmrstt***4231###NOTICE: BL31: v2.2(release):
NOTICE: BL31: Built : 17:00:51, Aug 23 2021
NOTICE: FDT check fail.
NOTICE: BL31: No DTB found.
NOTICE: TZASC config:
NOTICE: 0x00100000@0x01f00000 (RW/N) Ree
INFO: ARM GICv2 driver initialized
INFO: BL31: Platform setup done
INFO: BL31: Initializing runtime services
NOTICE: not find OPTEE, if system not have OPTEEe, don't care OPTEE error or warning message
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x3e000000
INFO: SPSR = 0x3c9
U-Boot 2019.04 (Nov 02 2022 - 14:14:02 +0800), Build: jenkins-Backend-BSP-CCI-8115
Read power trim = 0x00000000
remap_data 8
pwm_id:0 pinmux = 0x1
pwm_id(0) pwm_pinmux(0x1)
pclk_freq(30000000) div(3)
id = 0xc8 0x51 0xc8 0x51
env_nand_load:read nand env0 sucessful
env_nand_load:crc env0 sucessful
env_nand_load:read nand env1 sucessful
env_nand_load:crc env1 sucessful
OK
misc_init_r: boot time: 4162806(us)
misc_init_r: boot time: 4236960(us)
Set CPU clk 1200MHz
[UID] = 0x000003c1
Warning: eth0 MAC addresses don't match:
Address in SROM is e0:ba:ad:ef:92:e7
Address in environment is 00:00:23:34:45:66
[Dynamic change partition Warning]Use default partition info,ret is -19!
Hit ctrl+u to stop autoboot: 0
HKVS $ setenv ';pritenv
HKVS $ setenv ';printenv
HKVS $ setenv ';printenv'
HKVS $ setenv ';update
HKVS $ setenv ';tftp
HKVS $ setenv ';tftp'
HKVS $ setenv ";tftp"
HKVS $ setenv bootcmd ';update'
HKVS $
By the way im using this ttl converter
Thanks in advance.
NDD>XSAT
UNZOK!PCK[120]
table1
CPU1200 DONE
table1
ddr init done
HVYOK
UNZOK!
atf.bin RSA ok!
check sum ok!
uboot RSA ok!
smp(bl31)
INFO: SPSR = 0x3c9
remap_data 8
OK
Set CPU clk 1200MHz
[UID] = 0x000003c1
HKVS $
CP2102 USB 2.0 to UART TTL Converter
Thanks in advance.
