Mallesh Mayasa n3wb Oct 21, 2019 1 0 india Oct 21, 2019 #1 Hi could you tell how to recovery hikvision dvr output.you have any software.
alastairstevenson Staff member Oct 28, 2014 16,473 7,230 Scotland Oct 21, 2019 #2 Mallesh Mayasa said: Hi could you tell how to recovery hikvision dvr output. Click to expand... What caused the problem? The firmware can be re-installed using the Hikvision tftp updater. TFTPServ Hikvision IP Camera Emergency Firmware Recovery TFTP. Check this thread for info on how to use this tool to un-brick your Hikvision camera. ipcamtalk.com If that doesn't work - you'd need to connect to the serial console using PuTTY to see what's happening. Download PuTTY: latest release (0.83) www.chiark.greenend.org.uk
