Hello, I bought a new HikVision NVR: DS-7608NXI-K1
I currently have the latest software installed: V4.82.000 build 240224
I have continuous recording set in the NVR and people and car detection enabled. In the iVMS-4200 application I can filter detected events. And it works fine, although not very user-friendly.
However, I still have a problem with something else. So, I want to use the Hik-Connect app for Android. I added the recorder locally in the application using the IP address. The application connects to the recorder correctly. Unfortunately, when viewing the recording, I only have a blue line on the timeline with no events marked and I can't turn it on anywhere:
I see on the Internet that this application should display icons with the ability to filter the type of detection. Here is an example found on the Internet:
I have VCA enabled in the cameras and NVR.
I tried turning on the "Notify iVMS-4200" option
I downloaded the latest version of the Hik-Connect application from: 海康威视产品服务门户
I don't know if something else needs to be turned on for this to work?
Thank you for all your help.
