Hi everybody,
I have an IP camera from Aevision model AE-2AE2S-0406-VP and an Hikvision NVR model DS-7604-NI-E1 / 4P/A , both camera and NVR are claiming that supports POE.
The problem I have is that no matter how I'm trying to connect the camera to NVR via POE, the nvr does not see it. It doesn't even powering up the camera, meaning that the camera green led is off and there seems to be no link between nvr and cameras via utp cable.
I have tried to use an adaptor cable but is still not working.
The only way of connection them was to supply the camera via an external 12V, 2A supply through dedicated camera port, but this is not a solution for me.
How can I use this cameras with this nvr, but via POE from NVR ?
I also have connected to NVR a second camera model from Hikvision which works , but with AEVISION it doesn't.
Could it be that the POE protocols are different ?
I could not get more info from AEVISION site regarding this specific camera ... , I also sent an message to their support center but sincerely I don't expect too much support ... .
Any help ?
Any help ?
