- Jan 22, 2016
- 76
- 19
Have a Hikvision DS-7108N-SN/P NVR (firmware V3.0.13) that won't boot past the boot/splash screen. On the connected monitor all you see is the message "Embedded NVR" with Hikvision logo.
I set this NVR up for a family member at a remote location. They had a break in recently and caught footage which is stored on the NVR. They feared the burglars might come back and possibly take the NVR so turned it off (using the correct shut down procedure) and took it home. Now when plugged back in it won't boot past the splash screen
There is footage on the NVR we would like to give to the police. Not sure about the best way to try and get it.
Unfortunately I'm approx. 100 miles away so won't be able to physically gets my hands on the NVR for a couple of weeks. I've found a copy of the correct firmware and instructions on how to flash it via TFTP on another thread so I will probably try that.
If the NVR cannot be saved is there any method to manually extract the video directly from the hard drive? I've done a quick search and it seems like Hikvision use their own proprietary file system. Will the hard drive be encrypted too?
The annoying thing is it's been working fine for 9 months and now the one time we actually need something it decides to fail
I think I've learnt that a farmers definition of a "watertight" building is a bit less rigorous than most!
