Hik Batch Tool - Add multiple cams at one time to NVR?
OICU2
BIT Beta Team
Jan 12, 2016
923
1,666
USofA
Does the Hik batch tool allow you to add multiple cameras to the NVR at one time? For example, swapping to a new NVR, all cams are already configured and running on the network, just need to add them to a new NVR. Is it possible to do this in a batch?
The Batch Configuration Tool is more about camera management than connecting then to an NVR.
Try the Quick Add facility under the NVR web GUI Camera Management page.
It will find the cameras like SADP does and allow one-click adding.
Reactions: OICU2
