Help with NTP server issue.
ingeborgdot
Pulling my weight
May 7, 2017
749
174
Scott City, KS
My NTP servers just don't seem to keep time. On my Hikvision cam, it fails to work when I do the test, but when I put it in DHCP, the test works. My Dahua cams don't keep proper time either. Do I need to put them in DHCP? Thanks.
What is the DHCP server? An NVR? If so, it an NTP server address may be part of the DHCP config passed to the camera. On my Dahuas, there's a box for NTP server address under System, General, Date&Time. I'm using 128.138.140.44 for the NTP server. My cameras have static IP addresses and can't access the Internet except for hitting that IP on port 123. If you have a firewall, make sure outbound UDP 123 is allowed to the NTP server of your choice.
