Hi,
I have an Herospeed NVR with several cameras attached through PoE ports. I can see all the cameras via the NVR web interface but I wouold like to setup them in another LAN app via HTTP, RTSP or ONVIF. I've tried some URLs found online but none worked. Do you know what I can use to do this or if there is an option in settings to enable external share?
Thanks
Thanks
