I did read the cliff notes main reason I am posting great info but I need this asap. Here is brief over view of the situation. I live in a rural area and we have a 58 yr old pervert/ peeping tom/thief, serious issue. I am tired of spending most nights keeping a eye out/patrolling around the house for this creep.
I have toyed with a camera system for some time so now it is time to put one in. My needs most likely are a lot different then most on here. I am more in need of a surveillance style system. I dont need a hugh HDD for recording if it just gives me three days etc... That would be plenty the house is never left unattended. I need to keep this as simple as possible my parents/family stay with me and they need to work it when I am gone which is quit a lot. It would be nice to access the cameras when Im away.
The area I need to cover
360 on the house single story ranch style maybe 20ft out.
Front of house to the road is 130ft need IR coverage to at least make out someone moving around on road.
sides of the house is open fields with fences about 100 ft out on each side. No need to reach the fence maybe 20 to 30 ft on each side of house, again with more detail on night surveillance.
The rear is a doozie distance to furthermost barn 425ft need at least the front side with some night capability just need to make out movement. I also have three other buildings that need coverage that are around 125 to 150ft ft from the main house. On all out structures all the entry points face the house no doors or windows on sides/ rear. There is also a security light(big ones street style) on 2 of the structures over the entry points. I can run lines no problem and mount on poles if needed. Dont need 360 on any of these just the front entry points. basically from the rear of the house straight back 425 to 450 ft maybe 100ft wide area.
I was looking at the amcrest system 4k with 6 cams and NVR $750 amazon. I was thinking of doing a 7 and 8th camera. with one of those being a PTZ for the roof of the house So i could cover a 360 area or focus on a specific point. Really have no need for audio either. But now I think 10 cameras and I guess a 16 ch nvr would be better choice. Cameras style? I know a couple will probably have to have long runs.
I assumed the 4k cams would be the best. Glad i didnt order before finding this forum. Id like to stick with a easy unit and a cheaper unit. I dont really want to sock thousands in this. It is easier to replace cheap stuff as it dies then repair expensive stuff usually. I worked overseas a lot and we have major issues with camera systems all the time. the sand box does a number on our systems. One of the main reasons, I havent did this yet is because of all the issues we have at work with these things. ANd our stuff is like six figure$$$$ systems IR/thermal they stay tore up more then they work.
ANy help/recommendations would be great.I am researching regardless great info here. I need this quick so I guess, I will be stuck with package deals.
