@Shark92651 note that the RAM you linked is a single 16 GB stick which means you won't be able to use it dual channel. If you encounter unexpectedly high CPU usage, there's a possibility that this could be related. I never did any single vs dual channel tests with Blue Iris to know if there really is a difference.
Otherwise, that looks like a solid build.
I am only half-kidding, I need to leave 1U of space above this case so the PSU can breath out of the top anyway.
