Hello, as i said in my member introduction post i want to change my chinese cameras with dahua cameras
I take a look at this 3 models, (looking also at my money
) but any other advice is appreciated
IPC-HFW2431T-ZS
http://pl.dahuasecurity.com/download/product/20180205/dh-ipc-hfw2431t-zsvfs_datasheet_20180202.pdf
IPC-HFW5241E-S
https://www.dahuasecurity.com/asset/upload/uploads/soft/20190506/DH-IPC-HFW5241E-S.pdf
IPC-HFW4431E-SE
https://www.dahuasecurity.com/asset/upload/download/DH-IPC-HFW4431E-SE_Datasheet_201707181.pdf
The IPC-HFW5241E-S Model have a starvis sesnsor CMOS but only 2Megapixel, the other 2 have a progressive CMOS with starlight feature (that i think it isn't the same thing of a starvis sensor).
The Starvis sensor is better than the other two? I speak in terms of light, you can have brighter image? (naturally if u have some source of external light
IPC-HFW2431T-ZS have 20FPS it could be a problem?
I would like to take the 4MPx camera, but as i said any good advice is appreciated
My NVR is a Dahua NVR4208-4KS2.
Thank you for your time
IPC-HFW2431T-ZS
IPC-HFW5241E-S
IPC-HFW4431E-SE
