I connected two of my new Dahua cameras (different models) via a PoE switch to my router (one at a time) which is connected to my WIN10 machine, then opened up the default 192.168.1.108 in IE. I logged in successfully thru the web interface and changed the IP on one of them, as well as the admin password.
Then, I connected them one at a time to my NVR5216, and they immediately locked out. No luck adding them manually with the new IP and login. Tried everything I could think of. After that, I reconnected them one at a time back thru the PoE switch and to my router. When I tried to bring them up in IE, neither was found, one with a new IP assigned and the other still with the default 192.168.1.108.
FYI, no reset button seen on the inside of the IPC-HFW1320S bullet camera. I pushed the button I found on the inside of the IPC-HDBW4431R-AS to no avail.
The cameras that I hooked up straight out of the box to the NVR5216 work great. Didn't change their IP addresses from the default. Looks like the NVR just assigned their own to them.
