have dahua NVR, can you run second monitor 30m away?
wozzzzza
Pulling my weight
Jan 5, 2015
485
111
i have dahua NVR in the house with monitor connected, spend a lot of time in the shed 30m away and want a second monitor out in shed, is this possible or not?? if so how do i do this??
HDMI splitter + HDMI-over-CAT5 adapter should work for you, assuming you have an unused Cat5e run. Otherwise you'll need to use a HDMI-over-IP set which are unfortunately much more expensive.
If by chance you have a computer out there with Wifi you could install Smart PSS Lite on the Mac or PC.
look for KVM HDMI extender for CAT6 cable on amazon / aliexpress / other retailers...
it allows not only sending HDMI over CAT6, but also supports 2 way USB connection for remote mouse...
Reactions: TonyR
