I've got an IPCam application that's a bit different. Will it work?
1) I have 8 tennis courts, each with an IP camera running 1080p60. Yes, that's 60 fps, since in tennis the frame rate is hugely important.
2) I want to run the 8 streams into a direct-to-disk recorder at full 1080p60 using H.264. So far, so good.
3) The hard part: I want to show the 8 streams on 8 TV's in my lobby. I want the full resolution and rate. I'm worried this will overload the BI UI.
3a) I think I need the Blue Iris software with one window in each of my 8 video ports. All of the wiki pages tell me that running the UI at full res is a bad idea and that substreams are the way to relieve the load. For my application, having full resolution and frame rate, rather than substreams, is the point.
1080p60 = 124 MP, 8 of them puts me at 992 MP.
I'm not doing any triggering, it's full-time recording to disk.
If I buy @bp2008's rule-of-thumb system, say 8 core + HT on a good 4-channel memory subsystem, am I ok?
Thanks,
David
Thanks,
David
