The Automation Guy
Managed switches still need to be initially configured for the network they're on even if they're not being actively managed during operation.
That is incorrect.....
By default, managed switches are set up to run just fine as an "unmanaged" switch. They don't come set up with some "random" set of settings that prevent it from working on a normal network. They come set up in a mode that will work on all basic networks, and then it is up to the network administrator to customize the settings for their specific needs if needed.
....lots of variables when it comes to network configurations.
That is true, but by default every switch (including managed switches) are set up to work on a standard network without having to change any settings.
If a network admin has changed the settings on their network to something more complicated that breaks basic network functionality, then they are also knowledgeable enough to set up their managed switch prior to putting them into service. The opposite is not true however... Manufacturers don't ship their managed switches with some weird settings that break normal network functionality because that would require someone to log into the switch and play with the settings it in order for the switch to work on EVERY network, including the more advanced ones that might have some weird settings that break normal network functionality.
So with a managed (layer 3) switch you have the ability to.....
- enable a DHCP service to assign network address to connected devices...... but that service is not turned on by default
- segment your network using VLANs..... but the switch comes already set up with a default VLAN that includes all the ports (meaning it "works" out of the box on networks without VLANs).
- define routing rules to limit or control data transfer across the switch..... but no data is limited by default
