I have the PC built and all but (4) cameras installed. With (4) cameras left to install I am seeing about 32% CPU usage while running the BI service only. If I open to view the cameras, CPU jumps up to 82%- 87%. I have a feeling once I add he last (4) cameras I am going to peg the CPU when the UI is open for viewing.
The PC:
6700K CPU
32 Gb's of RAM
(2) 8Tb Seagate Skyhawks for storage
(1) 240gb NVMe drive for the OS
Cameras:
(10) Hikvision 4MP cams @ 20fps
--Will be adding (4) more---
BI Config:
Recording all cameras 24/7 at full 20fps
Hardware acceleration is "ON"
Direct to disk recording is "ON"
A few things I DO NOT want to compromise:
- Full 20fps recording
- 24/7 recording
- Zero latency playback during remote desktop viewing
So the question is.....Other than messing with the options I outlined above, "Is there anything else I can do to minimize CPU usage while the UI is open for viewing? " I am sure I will still be under 50% CPU with just the service active, but I do not want to PEG the CPU while viewing the recordings or monitoring the cameras. Are there any further tweaks I can make to the BI software or even the PC? Would Overclocking the CPU help any?
I was hopeful the 6700K would hold up for 15 cameras running wide open, but I am concerned now
The PC:
6700K CPU
32 Gb's of RAM
Cameras:
BI Config:
- 24/7 recording
