Before the comments flood in, this build was done as a project/for-science build.
This is not an endorsement of this type of build for a reasonable person, or (really) anyone tbh.
This is simply a shameless attempt to try and get the IPCT contributor badge
Once a year I get bonus "mad money" and I do some project that might not otherwise make sense:
TLDR - Executive Summary : Performs great, but still buy a used desktop. Server motherboards do not have most consumer motherboard creature comforts.
This build set out to answer some nagging questions probably only I had.
I budgeted for an AMD EPYC 7262 server CPU (8C16T) $600 because it supports octa-channel memory unlike the cost-optimized 7232P with a crippled memory controller (article here: AMD EPYC 7002 Rome CPUs with Half Memory Bandwidth). The closest consumer variant would be the Ryzen 9 3950x, which is 16C/32T, dual-memory-channel. The Threadripper 3960x does offer quad-channel memory but is also 24C/48T and the CPU itself is nearly $2000 USD so it shouldn't be a fair comparison imho.
While this build is completely unnecessary for simple NVR computer work, since (someday) AMD R7, R9, Threadripper & EPYC CPU's will show-up on the secondhand market, I figured it would help the community to know where they stand against their Intel counterparts.
It's also important to know you could just as easily buy 3-4 standard desktops and support similar numbers of cameras, and likely spend less to buy those extra systems than cramming everything onto a single system.
This EPYC server will finally replace my i7-2600k pulling Blue Iris duty and consistently drawing 120-125 watts (with 140 watt peak).
- 2018 was pfSense & first big pile of IP cameras from Andy.
 - 2019 was Ubiquity network build out
 - this is 2020's project. The EPYC server build.
- Is CPU memory bandwidth a factor in performance (for Blue Iris) beyond standard consumer grade dual-channel memory.
 - How exactly does an EPYC chip perform compared to the extreme AMD consumer chips like Ryzen 9-3950x, Threadripper 3960x, Threadripper 3990x.
 - Server chips are meant to run 24x7, and in data centers. Does that equate to them being more or less energy efficient for 24x7 operation?
 - How much can a graphics card offload from the CPU, and what is the trade-off in power usage.
 - Do consumer GPU's offload CPU equally between consumer and business/creator versions of the same product?
 - Are there limits to NVDEC that impact the consumer cards (GTX970, RTX2060) that do not apply to business/creator cards (Quadro, Tesla) <- wont be testing a $6k Tesla card unfortunately.
 - Could AMD systems someday make sense, or will Intel chips with integrated GPU's always reign supreme for this use case?
 - How efficient/cost effective would a new 7nm Server chip be compared to my extremely old i7-2600k which is pulling Blue iris duty and runs high CPU 24x7.
