Ok so long time engineer recently started using NXI’s over the 7608’s but have been hitting an issue.
on 3 units now I have had the built in POE Hub fail after working for a few weeks, if I power the camera via an Independent poe switch plugged into the nvr or even plug the cameras into the hub and add 12v to the jack the cameras are fine but the poe on the NVR will not kick in and the poe power lights flash once when you turn the nvr on as you would expect and then stay off .
to clarify and avoid the generic comments:
*yea cameras all work on other machines.
*yes until the failure all cameras worked on the NXI’s.
*no there is no moisture damage.
*yes I have checked the poe settings on the NVR.
*yea I have checked the red/white cables with a meter for voltage and drawtest both are fine.
*yes I have tried power supply from another working nxi to rule that out too.
these units worked fine but the. Suddenly died.
I have read a lot of posts about overload and power spikes killing the poe hubs but none on how to fix or prevent the issue especially since I have surge protection in place…
My question is has anyone else experienced this poe failure and have you found a fix other than buying an independent poe hub and plugging it into the nvr or individually powering each camera?
